Couple questions, 1995 2.0 stratus
Subscribe
Apr 14, 2009 | 09:42 PM
Question number 1:
On the tube that carries air from the air filter box to the air box that sits on top of the throttle body there is a small diameter hose that plugs into it on the back side. Where does the other end of this hose belong?
Question number 2:
Holy crap, I just spaced out and can't remember what I need to ask... I'll have to sit on this for a bit haha!
Reply 0
Apr 15, 2009 | 08:54 AM
The other end of the cable usually will lead to the engines valve cover. there should be a nipple where the other end of the hose will plug into.
Quote:
Question number 2:
That's OK. Just start a new post when you remember
Reply 0
Apr 15, 2009 | 08:44 PM
Hmm, I must have some mis-matched parts then.
I have a 2.0 SOHC engine and the valve cover has no receptacle for a PCV valve. The motor utilizes an oil separator mounted to the front of the block and the PCV valve is in a hose that leads from the oil separator to the intake manifold.
The engine is not the original, it must be from a different model and they kept the original intake tube.
I suppose I will just plug a fancy little cone air filter into the hole and leave it alone.
Reply 0
Apr 16, 2009 | 12:35 PM
I suppose that will work. I don't have (nor have ever seen the 2.0). Maybe see if you can find the same setup in a junkyard that hasn't been stripped apart that will help quite a bit. It is my understanding that the 2.0 is shared with the Neon, so maybe you've got a neon engine in there
Reply 0
Subscribe
