1999 breeze transmission swap HELP!!!!
Old Apr 27, 2009 | 10:18 PM
1999stratus's Avatar
1999stratus
Default 1999 breeze transmission swap HELP!!!!
Hi we just did a transmission swap in a 1999 plymouth breeze which is the same as a 1999 stratus and i checked everything before doing the swap to make sure the 2.4l breeze expresso tranny worked in are 2.0l breeze and well everything work and lined up except one dam plug on the trannys harness is not the same and where we bought the transmission was off crigs list and is a 2 hour drive and we didnt think to grab it cause we figerd it was the same. My ? is any one know what the 4 plugs do that go into the transmission? and what would happen if i left it unpluged?
as you can see in the pics of the harness its the the plug with the orange rubber around it its not the one that screws in or the small 2 plugs but that other one.
