stalling, check engine light
Old Jul 11, 2009 | 07:26 PM
pbear's Avatar
pbear
Default stalling, check engine light
I'm working on my daughters 99 stratus. check engine light-code 132. Runs good for a couple of minutes after start. Then won't take gas until you floor it. 132 showed O2 sensor. I have replaced both of them and installed new plugs, wires, air filter. BTW it is a 2.4 with about 130000 miles on it. I understand that when cold it runs on a closed loop until the sensors are up to temp. I have tested the TP sensor and the Map sensor.
Both tested good. No other codes present. When I reset it, it is ok til it warms up and the stall occurs. soon after I get the check engine light. Hope someone has a solution.
Thanks
