Rough Idle
Old Jul 16, 2009 | 12:09 AM
MistaRamMan's Avatar
MistaRamMan
Default Rough Idle
Im having an issue. My stratus has a rough idle so I stepped on the accelerator and the car wont go past 3500rpm. I just changed the plugs and its still doing it. There are no codes showing so any ideas?
Old Jul 16, 2009 | 12:39 AM
MistaRamMan
ok i just pulled the vac line off the PCV valve and the idle instantly got better so does that mean that the PCV is bad. What the best way to check it?
Old Jul 16, 2009 | 05:47 AM
nightrider340's Avatar
nightrider340
take it off and shake it... if it rattles alot its good.... but heck they are only a few bucks and only take a second to change... I would just replace it
Old Jul 17, 2009 | 12:25 PM
DevilsReject's Avatar
DevilsReject
Noob Assassin
+1
I would just replace it as well. I'd also make sure your air filter is good too.
Old Jul 21, 2009 | 02:19 PM
MistaRamMan
Well I found out why I had no codes...the light bulb on the dash burnt out so the indictor was not coming on. But after hooking up a scanner I got P0172 - System Rich. Well that usually mean that the computer is telling the injectors to dump more fuel, thus messing up the AIR/Fuel mixture. So my question is could my MAP sensor be bad and if so how do I test it. If its not the MAP what else coould it be? Thanx
Old Jul 21, 2009 | 02:23 PM
add|ct's Avatar
add|ct
Sure your O2 sensors aren't the problem? By the way, thanks for reminding me I need to change my PCV valve.
