Twp Dipsticks???
Old Jul 26, 2009 | 09:24 PM
PATRICKPBME's Avatar
PATRICKPBME
Question Twp Dipsticks???
Just bought my daughter a used 2003 Stratus. Went to check the oil. There is a dipstick toward the back of the engine comprtment with the label "engine and another near the air filter which appears to go right to the oil pan. I guess I had assumed that the one in back was for the ATF but ...
Also, does anyone know where I might get a reasonably priced owners manual? Thanks in advance.
Patrick
Old Jul 27, 2009 | 06:00 PM
john1782's Avatar
john1782
Dipstick by the air filter on the 02 R/T is for the ATF.
Old Jul 29, 2009 | 01:31 PM
joe0121's Avatar
joe0121
I agree, mine has a white handle (ATF).
Old Aug 3, 2009 | 08:24 PM
add|ct's Avatar
add|ct
Yeah, you could just pull the dipstick and if its pink its ATF and if its black its your oil stick. =)
...another thing to check is see if the stick has markings relative to temperature. I believe only the ATF stick will have marks relative to the temp.
Old Aug 4, 2009 | 06:02 AM
john1782's Avatar
john1782
Also, the ATF dipstick is shorter and a bit wider
Old Aug 4, 2009 | 10:49 AM
add|ct's Avatar
add|ct
Now you're just getting ridiculous. You know I can't tell size differences at that scale.
