Running rough
Old Aug 2, 2009 | 11:39 PM
mike0513's Avatar
mike0513
Default Running rough
my car is running rough...i posted earlier about my 0-60 time being around 10 seconds and it should be around 7.5...how much would a full tune up help? and the only code its throwing that i know of is idle is too high.
thanks in advance
Old Aug 3, 2009 | 05:20 AM
lancejonesmusic's Avatar
lancejonesmusic
Get a can of carb cleaner and spray around some. I had a rough/high idle (it would be low and rough sometimes and then be high sometimes) and I decided to spray some carb cleaner in an area where I thought I heard some extra air noise( I have a cold air intake so I thought maybe it was just the device sound). While Idling low, whil squirting all over the throttle body area, the RPM's boosted immediately. I ended up replacing the gasket for it, but while doing that, I found a part that had lost a screw and was simply sticking out the front of the throttle body causing basically a 3/4 to 1 inch vacuum leak.
This is after I tuned the car up and even replaced the coil packs( mine has 2 coil packs).
I got a screw and lock washer and locked that part down and it purred like a kitten, no codes.
Your problem could be a tune up or vacuum leak or fuel, but I rattled around with mine for a while, and I figured it out, so I do recommend checking vacuum leaks right away!
It will cost very little to buy the carb cleaner and could save a lot of time and money-
Old Aug 3, 2009 | 12:14 PM
mike0513's Avatar
mike0513
alright...thanks for the help...you think this will help my acceleration problem to?
