Thanks. It was located kind of under the radiator. The thing I mssed with was right near where you drain oil and coolant. When i unscrewd the "pin" though, no liquid came out... just chemical pressurized vapor. I guess it has to be either coolant or a/c refrigerant. After it happened I did test the a/c and it seemed to blow pretty cold air, but its been awhile since I used it - not sure if it was cold as its supposed to be. And after I drove around for awhile I checked my coolant level and everything seemed ok. nothings leaking or anything. maybe i just let out some pressurized coolant.
