Solenoid pack replacement
Old Jan 10, 2010 | 08:49 PM
ousotsuki's Avatar
ousotsuki
Default Solenoid pack replacement
1999 2.4 Leaking tranny fluid. Seems to be leaking around the solenoid pack/shift solenoid assy area. I can't rule out if the leak is coming from any of the sensors or fittings above the assembly, but I can see fluid build up around the front cover (with the torx screws) edge after I wipe down the area while it is running.
The parts picture shows only three bolts. Is this unit replaceable without tearing too much apart? I can only see one bolt head, but didn't have enough time tonight to see if I can get tools on the other two bolts. Once I get parts in hand I will have a better idea if I can do this repair on the street.
Any heads up would be appreciated. Thanks.
Old Jan 11, 2010 | 03:57 PM
circumventor's Avatar
circumventor
ya its 3bolts i dont see tehm leaking much but teh hoses are above teh sol and they leak all the time teh 3 bolts are 10mm adn pritty ez to remve but yall gotta move teh speed sensor.
