2002 stratus r/t coupe wheels
What year/trim mustang wheels you looking at? If we know that we can see if the offset and lug spacing and count are correct. The things that will usually hang up is if the offset is too little and there is no room for the calipers. The other thing to look at is if the lug spacing is correct.
You have 5 lugs @ 114mm spacing
35mm (or greater) offset.
5.6 (or greater) backspacing
What's that mustang got? If your lugs are the same, and it has ample offset and backspace, you're good to go.
Come back with pics when ya get them on if it works
