remote start/alarm
Old Feb 19, 2010 | 03:33 PM
dlbjmb35's Avatar
dlbjmb35
Smile remote start/alarm
Hello. Thanks for your help in advance.
I purchased an Ultra Start G11 1280 Pro remote start/alarm. I am looking to install the alarm but need connection information that the install manual is asking for. Please help me by telling me where each of these items need to be wired to.
Here they are....
Starter Output(+)
Heater/Accessory Output(+)
12 Volt Input(+) 30 amp
Selectable Output(+)
Ignition Output(+)
Diesel Wait to Start Input(+or-) <-----not used in my case
Brake Switch Input(+)
Horn Output(-)
System Ground Input(-)
Park Light Output(+) 10amp
Hood Pin Switch Pin(-)
Tach Detection Input(A/C)
Re-arm Output (-)250ma
Trunk Release output(-)250ma
Dis-arm Output(-)250ma
Starter Kill
Ground While Running Output(-)
If anyone can elaborate on where each of these items are located so I can get the wire hooked up I would appreciate it!!
Thanks again for any help....
Old Feb 19, 2010 | 07:28 PM
bad venge's Avatar
bad venge
Section Moderator
2000 Dodge Stratus Alarm, Remote Starter, Keyless Entry Wiring Information
Constant 12V+ Red or Pink/Black or Red/Blue Ignition Switch Harness
Starter Yellow Ignition Switch Harness
Ignition Dark Blue Ignition Switch Harness
Ignition 2 Dark Green/Red Ignition Switch Harness
Ignition 3 Black/White Ignition Switch (Power, Heat)
Accessory Black/White Ignition Switch Harness
Tach Black/Gray Or Blue/Gray 4 Cylinder Engine (2 Cylinder Setting)
Neutral Safety Wire Black/White (-) Gray 10 Pin Connector Driver's Front of Engine
Brake Switch White/Tan Brake Switch
Trunk Release Black/White Driver's Kick Panel
Trunk Pin Tan/Black (-) Driver's Kick Panel
Parking Lights Black/Yellow (+) Driver's Kick Panel behind Fuse Panel
Head Lamp Green Light Switch
Factory Disarm Light Green/Orange Left Side of Dash 20 Pin Connector Pin 19 (+)
Door Trigger Yellow (-) Under Fuse Panel 6 Pin CON
Door Lock White/Light Green Near Fuse Panel 20 Pin Connector
Door Unlock White/Light Green Single Wire System 1.5 Ohm
Driver's Lock Orange/Black BCM
Driver's Unlock Dark Blue/White BCM
Passenger Unlock Pink/Black BCM
Horn Wire Green/Black (-) Steering Column White 3 Pin Connector
Windows Up LF=Light Blue/Gold, RF=Brown/White, LR=Blue/White, RR=Gray/Black
Windows Down LF=White/Gold, RF=Purple/White, LR=Red/Black, RR=Green/White
