2002 Dodge Stratus R/T Sunroof leak
Old Feb 21, 2010 | 04:07 PM
matty's Avatar
matty
Default 2002 Dodge Stratus R/T Sunroof leak
I have a 02 Dodge Stratus R/T 3.0L V6 and the sunroof has started leaking after some pretty heavy rain. We found no clogs when pouring water down the drainage tube. After we pulled the ceiling down, we discovered it is leaking through around the front-left rail assembly for the sunroof window (if looking at the car from the front). We put some silicone around the area, but it continues to leak from that spot.
Are there any recommendations on how to seal this spot properly?
Old Feb 24, 2010 | 05:59 PM
matty's Avatar
matty
Because the drain wasn't draining properly, water would overfill and leak through the sunroof rail assembly. So, I guess it's normal as it should never have enough standing water.
Although we didn't see anything significant come out the bottom other than a drop of water, it seems to drain fine now, and there is no sign of water inside the car.
Old Mar 5, 2010 | 07:56 AM
dazner's Avatar
dazner
i'm having the same problem bleh...
