I am working on a 2001 dodge stratus 4 door with the 2.7 motor. Car was not running due to a cam shaft position sensor. I replaced the sensor and the car started right up. Upon starting it was making a clacking sound which sounded like the valves hitting the pistons. I also noticed the oil light was on. I took the valve covers off and noticed some slack in the timing chain, there should be none correct? My question is the chain tensioner is controlled by the oil pressure correct? And if so should I assume the oil light was due to a bad tensioner or could it be the oil pump causing the tensioner to not work giving me slack in the chain. What do I need to replace please help.
i noticed you said you replaced the crankshaft postion sensor of your dodge stratus. i myself have a 2.7 liter. PLEASE, how did you fix it. i can't even locate where mine is..thanks alot
