2001 Stratus power window problem
Old Mar 11, 2010 | 03:19 PM
MichelleM's Avatar
MichelleM
Unhappy 2001 Stratus power window problem
None of the windows will roll down all of a sudden. Everything else works. I already had someone check the relay/fuse thing and that isn't it. Has anyone else had this problem?
Old Mar 15, 2010 | 12:35 AM
RAMKIN326's Avatar
RAMKIN326
Mine is kinda the same except that they only roll down from the driver side i think it the lock switch that burned out on me but i dont want to dig into it with out getting some pov first
Old Mar 15, 2010 | 11:11 AM
02sxtstrat's Avatar
02sxtstrat
"Had the same problem and did the same by replacing the switch and all but still didn't work. Took it to the shop and learned it was a pink wire in the driver side door where the wires come from the engine area to the door, bascially if you look at the door hinges you will see the rubber boot that covers the wires. This is the wire broke at on my car."
This is the same problem I had in my car and this is the solution that took care of it for me. I posted this back sometime last year and I hope it helps you.
