New here. Wits end with Stratus Code
Old Apr 20, 2010 | 12:23 PM
whitebread's Avatar
whitebread
Default New here. Wits end with Stratus Code
Hailing from Northern Kentucky. Picked up a 97 Stratus a couple months ago. Now wont start. Reading Codes P0351 and P0352. Replaced the coil pack. Replaced the plugs. Swapped the wires. Still no start, same code errors. Appreciate any help?
Old Apr 20, 2010 | 02:36 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the first generation Stratus section,
FF
Old Apr 21, 2010 | 07:41 AM
ratsttam's Avatar
ratsttam
It would be helpful to know what engine you have in there, and which trim level. 2.0, 2.4, 2.5v6 / se, es?
# P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
# P0352 Ignition Coil B Primary/Secondary Circuit Malfunction
Sounds like you're on the right track, I would trace the wires back that lead to the coil packs to make sure they're not chaffed or broken anywhere. Double check all the connections on the packs you already replaced.
Old Apr 21, 2010 | 08:43 PM
whitebread's Avatar
whitebread
Its the 2.4 liter. Checked more stuff than I can recall, including many wires and relays. Also now replaced the ignition switch, cam sensor and crank sensor. Still wont start. What to do?
