Headlights and turn signal won't turn off 2002 Stratus RT
On my 2002 stratus rt, the turn signal won't turn off, it is like the "middle" position stopped being there. At the same time, my headlights won't turn off and can't be dimmed-the brights are always on. Any ideas?
Pretty easy fix. Remove the cover off the top of the steering wheel column (there is likely 2 screws going up from under the steering wheel). Under that is the assembly with the headlight dimmer switch/turn signal lever. Remove that, and replace.
