changed dist cap now runaway rpm HELP
Old Jun 10, 2010 | 02:20 PM
pixelpadre's Avatar
pixelpadre
Default changed dist cap now runaway rpm HELP
Good news and bad news. The 2.5l engine runs so much better with new cap and rotor. Bad news is when I reassembled everything the idle was red lined. I looked under the hood and found one plug (IAC) I missed connecting at the throttle body under the accelerator cables. I hooked it back up and nothing changed.
What grevious error have I commited? Please respond. I only have one car.
I disconnected battery to reset thinking it needed to relearn but that made no difference.
Old Jun 10, 2010 | 03:03 PM
pixelpadre's Avatar
pixelpadre
One thing I did that might be a problem. To make room for my hands, I disconnect the vacuum line on a cylinder that goes to one of the cables on the accelerator swivel (for lack of a better term). but I did reconnect it. Did that cause a problem when I disconnected it and pushed it aside while I worked on the car?
Please help. this one sounds so simple. I am in the process of taking everything off again and reassembling it again.
Old Jun 10, 2010 | 05:47 PM
pixelpadre's Avatar
pixelpadre
Default fixed
Well, I re connected everything again and this time rpm was hovering 4000. So I shut down and started up a few times and now it dropped down to 750. I think the dist cap was so bad that the computer was over compensating and when I threw on the new cap it made the rpm go crazy.
