Welding & Car Battery
Old Jul 19, 2010 | 03:06 PM
qtband's Avatar
qtband
Default Welding & Car Battery
I'm still trying to figure out what went wrong with my Stratus (see my post "Quick Help Needed). I did do some Mig welding on the car and I disconnected the POSITIVE cable only. Should I have disconnected both cables? Did this somehow cause my problems?
Ken
Old Jul 19, 2010 | 03:14 PM
sapporo's Avatar
sapporo
you never disconnect the positive first or only. always disconnect the negative.
however I weld on cars all the time w/o disconnecting the battery and never had a problem.
did you ever think to connect a real scanner and see if you have communications, get a schematic and multimeter to check for appropriate grounds and power?
Old Jul 20, 2010 | 02:25 PM
qtband's Avatar
qtband
Found a fuse that was blown. That fixed the remote problem, however, it still didn't start. Galvanized Yankee said that an engine that doesn't start is lacking fuel or spark. I gave it a shot of starting fluid and it fired right up and kept on running. It's still working fine. Did the fuel "Dry up" in the intake or what? I just wanted to know....
Ken
Old Jul 20, 2010 | 02:30 PM
sapporo's Avatar
sapporo
ya, that's it, the fuel dried up in the intake!
