How can I disconnect the ABS
Hi,
I would like to disconnect the ABS. When I come into a turn at a brisk pace often there is water, or dirt, or snow on the inside and the damn sensor won't let me slow down cause it thinks there's a problem and senses the inside tire slipping -- thusly creating a problem!
Any Ideas?
Thanks,
Imre
Any Ideas?
Thanks,
Imre
Simplest way to disable the ABS is to pull the fuse that controls it. You WILL get a light on the cluster indicating an issue (which you can ignore). Keep in mind that ABS is a safety feature, and disabling it can cause problems later on, rather than just replacing the sensor that is giving you problems.
Hi,
Thanks for your reply, I tried the fuse while the engine was running but it stopped. The fuse was labeled ABS PCM. It's a 96 Stratus. I'll check out the relay after I eat. In Hungary it's dinner time.
Thanks,
Imre
Thanks,
Imre
