obd plug location
Old Aug 5, 2010 | 09:24 PM
bigtigga84's Avatar
bigtigga84
Default obd plug location
have an 04 and an 02 or 03 (friend doesn't know which his is), check engine lights are on. the 04 died out of the blue and now won't start. engine turns but won't fire. i've looked the 02 or 03 over a couple times and can't find the obd II plug anywere. a detail description of were it is or a picture would be awesome. i have issues with directions, just ask my dad lol.
Old Aug 6, 2010 | 10:45 PM
ratsttam's Avatar
ratsttam
Standard location is under the dashboard on the driver side. It may be hidden behind a small panel or bent up under the dash above the brake and throttle. If it's bent or moved, no amount of direction from us will help you. Just gotta get up under the dash and see if it's jammed up there somewhere.
