My car won't start
Kind of an off chance but check your vacuum lines.
My car wouldn't start once, I called AAA and he got it started by pushing it real hard and given it some throttle to start, Turns out it was because one of the vacuum lines poped off. After reconnecting it, this never happened again. I"m at 106K with a stock battery and alternator
I wish I saw this sooner. It most likely is your ground wire going to the battery. I had this same exact issue. I ended up making a new one, but there might be enough wire left to cut the old terminal off and crimp a new one on. Or just use a wire brush to clean it up really well. Let us now what you find out!
If you do get it started, go ahead and carefully pull the negative terminal while the car is running. If the car continues to run, you dont have any charging issues
Thanks again for all the help, I'm very grateful for your troubleshooting ideas. This is my first car and I've put in quite a bit of work to get it running like it should and I see a light to the end of this tunnel of obstacles. I love this car, and it's an awesome vehicle when it's working.
I'll keep you posted about whether or not changing the terminal worked. Thank you again.
It Starts! My car is running again! Before I went to get a new terminal, I went ahead a used sand paper try and clean up both terminals as best as I could and make them shine to get a better connection.
Under the positive terminal I found quite a bit of corrosion where the actual terminal met the bolt that leads to the starter and other parts of the car. I removed the nut and cleaned all those connections really well and hooked them back together. I don't know how I missed this before, but I believe that is what was keeping the car from starting. I should have done a more detailed check when I cleaned the terminals and post the first time, but I'm glad my problem is solved.
"I hate it when I'm right".
