do i need a new door panel?
Old Aug 25, 2010 | 01:06 PM
sniperi311's Avatar
sniperi311
Default do i need a new door panel?
I have an 03 dodge stratus sedan. The trim on my power windows broke, and the switches fell through into the door. They still work however. The question I have is. Do I need to buy a whole new door panel, or can i just buy the trim piece? It looks like i need to buy a new panel but I'm not too sure. Any help would be appreciated
Old Aug 26, 2010 | 05:02 PM
GALVANIZEDYANKEE's Avatar
GALVANIZEDYANKEE
It is hard to tell without actually looking at the panel. If you take off the panel there are a few hidden screws. Pop the small cover behind the door handle and the pull recess. There are screws under the covers. There is a screw on the edge of the panel just below the mirror. Pop the speaker grill. There are three screws in recesses. The rest is held by snap clips. The door handle must be detached from the actuating rod. Unplug all wire connectors. Put a box under the door the support the panel so that you don't put too much pressure on the connector cables.
