03 stratus ac random vents..help?
Old Sep 1, 2010 | 09:48 PM
2003 stratus in st.lo's Avatar
Default 03 stratus ac random vents..help?
im new, today first time on a forum. i need help .'please'..got 03 stratus and the ac vents have a mind of there own, one minute its on face vents, next its on defrost, if i play w/ switch, it just makes it more 'random. i read some complaints here but never heard answers, anyone of you ever found 'why' this is happing? im a mechanic, so i can fix my self, if i had more help where to start. thanks for any ideas.(oh, the ac always is cold,except when it randomly ,on its on, goes to defrost, then its kinda warm, like blend door half-open or???) help, please? thanks.
Old Sep 1, 2010 | 09:58 PM
Default 03 stratus ac random venting...help?
i dont know how this forum works, if anyone gets this, please tell me how, its ist time. i have ac vents that randomly go from defrost to face to whereever??? need help please. thanks.
Old Sep 2, 2010 | 10:59 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the Stratus section,
FF
Old Sep 6, 2010 | 01:18 PM
02sxtstrat's Avatar
02sxtstrat
This is what happend to me when my fan would only work on certain settings. Don't know if you have the same problem but this is what I had to go through "Ok so I have kinda the same problem, but I didn't have any problems with heat or cold air. The only problem I had was that the fan would work on #1, the lowest setting, but would sometimes make a grinding sound and would not blow any air out. On monday I had the fan set on #2 and it made the grinding sound, which it never did on any other setting but #1, and then it wouldn't blow any air out on #1 and #2 and only on #3 and #4. So took it in to see what the problem was and it turns out that the resistor and blower motor went out and recric door actuator went out. So we replaced all three for a cost of $500 and as of right now everything works ok." Hope this helps.
