Dash
Old Oct 27, 2010 | 10:10 PM
nate31891's Avatar
nate31891
Default Dash
Hey guys I need a little help. My dashboard or message center if you will has the check engine light on every time I run my car. I have checked everything regarding oil, coolant, transmission, and power steering fluids and they are full. So I really don't know what is making it do that. Any ideas? Any help would be appreciated
Old Oct 27, 2010 | 11:17 PM
rmckellar's Avatar
rmckellar
You need to use a code reader to pull the trouble codes from the control module(s). Take the car to an Autozone. They'll read the codes for free. The trouble codes will help direct you to what the problem is. Or, take it to the dealer or a repair shop and they can help you.
Old Oct 28, 2010 | 03:11 PM
nate31891's Avatar
nate31891
thanks, would I be able to go to advanced auto?
Old Oct 28, 2010 | 04:35 PM
dakota_raven's Avatar
dakota_raven
yes, advance or autozone will read your codes for free. check the gas cap. if not on correctly or if is bad it will give you a check engine light also.... just a thought!! good luck....
Old Oct 31, 2010 | 11:51 PM
nate31891's Avatar
nate31891
thanks guys appreciated
