Stratus Owner
Old Nov 23, 2010 | 10:19 AM
SweetStratus's Avatar
SweetStratus
Default Stratus Dash
Gauge cluster and dash
Old Nov 26, 2010 | 10:10 AM
ratsttam's Avatar
ratsttam
Nice ride! The cluster is too bright for my preferences (90% night driving, the dimmer the better for me, wife turns everything to max when she drives though, I think it makes it impossible to see down the road).
Good job on the 1.5din -> 2din conversion. The way the radio sits, it really limits what you can put in there. Too small to put flat 2din, and the shelf prevents a pop-up from being usable at all.
The rings in your cluster, are they custom made (and of what material), or did you find an online supplier? My '00 the gauge faces are white, with the orange back-lighting. Pretty sure the 1g Strats were standard with the orange lighting (and white gauges for '00 only). Was switching to the green hard to do, or did you just get a cluster from the Chrysler or Plymouth variety? I was interested in switching to blue lighting behind the white cluster.
I already have the black leather power seats and the carbon fiber trim pieces, 4speed autostick, cut open the front of the airbox which resulted in a nice growl and slight improvement in power.
Old Nov 27, 2010 | 12:53 AM
SweetStratus
its a double din in there had custom make room for it and custom fibre glass black panel and also the cluster can be dialed down on brightness. i used green leds everything lights up green the numbers the needles and with the glow the rings light up in the cluster and that ring thing was made. pic not great for the cluster lite up. everything was made in cluter not sold online etc. i even have to fuse the cluster cause of the leds in it
