97 stratus not turning over
Old Feb 28, 2011 | 11:32 AM
whitebread's Avatar
whitebread
Default 97 stratus not turning over
Has happened one or twice in the past and fixed itself.
Appears it no longer wants to play nice.
Turn the key to the ON position and lights come on, pump runs, and all.
Turn to the START position but no start.
Diconnected the ground, no help.
Help please.
Old Feb 28, 2011 | 03:23 PM
whitebread's Avatar
whitebread
Default Update
After trying again to start the car, I heard a slight dull clickng like sound from under the hood.
I went to Autozone and borrowed the OBD scanner.
I scanned, no codes.
I removed the scanner, no start.
I plugged the scanner back in.
No codes.
With scanner plugged in, started.
Removed scanner.
Started.
Greatful it started.
Whats that about?
Old Feb 28, 2011 | 05:35 PM
22DODGE22's Avatar
22DODGE22
Maybe you just need a new starter or replace the solenoid contacts in the starter cuz that's exactly the symptoms to the problem you are describing.
Old Mar 1, 2011 | 03:54 PM
whitebread's Avatar
whitebread
I will get under there this weekend and check the condition of things, and report back.
Thank you for your time.
