Status is starting too stresstus
Old Mar 2, 2011 | 08:36 PM
Lucien's Avatar
Lucien
Default Status is starting too stresstus
Ok so I got a 98 stratus with a 2.4L auto trans it cranks over fine but pops through the intake and wont run for more than a second. I have checked for spark and fuel both of which are fine I also have tried a new crank and cam sensor aswell as new plugs, the timing belt was replaced 3000km ago. and it has 90-100 psi of compression first stroke on all cylendars and 150-170 psi in 4 strokes. the catalytic converter is also intact the only thing I havent tried yet is a new pcm. any ideas???
Old Mar 2, 2011 | 08:53 PM
Lucien's Avatar
Lucien
Ok so after a day and a half of head scratching we finally found something. The dowel pin between the cam and gear snaped letting the exhaust cam "adjust" itself as it wished
Old Mar 2, 2011 | 11:00 PM
countryboi83's Avatar
countryboi83
glad you found your problem...if you need anymore help let us know.
