97 Stratus 2.4 vibration idle help
Old Mar 15, 2011 | 10:14 AM
JSTJ704's Avatar
JSTJ704
Default 97 Stratus 2.4 vibration idle help
I have a 97 dodge stratus 2.4. It has a vibration at idle which makes the steering wheel shake too. The vibration goes away when I give it gas and is worst in drive. I'am puzzled there is no codes.
Here is what I have done
Checked for vacum leaks
plugs, wires
fuel filter
map sensor
air sensor
idle sensor
cleaned throttle body
replaced motor mounts lower and uper
coil pack
air filter
The car drives great but at a stop light it has a vibration idle also in the wheel.
Anyone ever had this problem and now where to look? I thought EGR but you would think there would be code. also thought maybe the fuel pressure regulter too. The only sensor left is O2 sensor and crank postion sensor.
anyhelp would be awsome
thanks
Old Mar 15, 2011 | 10:53 AM
JSTJ704's Avatar
JSTJ704
could my timing be off a tooth
Old Mar 15, 2011 | 03:23 PM
JSTJ704's Avatar
JSTJ704
I checked out my EGR I noticed it opens and closes as I give to some throttle. The only thing I could think is fuel pressure.
