bolt on
Old Jun 30, 2005 | 09:21 PM
bjshu96's Avatar
bjshu96
Default bolt on
What are some good mods that can be done to my car. I want to keep it looking stock on the outside for now. Under the hood is fair game. I've been thinking about some kind of stabilizer bar and some kind of intake. Any good ones?
Old Jun 30, 2005 | 11:22 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
Default RE: bolt on
buy a cheap intake off of ebay, then buy a good K&N cone filter...it should already have a strut tower bar...its standard equipment. i also have solid front mount, because yours WILL wear out
Old Jul 1, 2005 | 06:57 PM
DodgeThis3's Avatar
DodgeThis3
Default RE: bolt on
Intakes and mufflers don't do much but its easy to do (the more work you have done the more they help)... Depends on what you have (year/engine/tranny) and your spending limit. There are lots of things you could do like a udp or intake manifold.. get a turbo/build up you engine... it all depends how wild you want to be. The easiest and cheapest performance is by doing weight reduction
If you have an automatic, I sell high stall torque converters. they help out a lot especially if you plan on modifying your engine and pulling more hp. Check out www.rezlo.com for info... if you need more info let me know.
Old Jul 1, 2005 | 08:34 PM
bjshu96's Avatar
bjshu96
Default RE: bolt on
My year is 2005 3.0L V6 5 sp. man. I'm very much looking in to some kind of intake
Old Jul 2, 2005 | 03:01 AM
DodgeThis3's Avatar
DodgeThis3
Default RE: bolt on
It's harder to get things for newer strat's because they haven't been around a long time, I think dreamspeed might have intakes for your strat or you could try to get something from ebay like badstrat suggested... check out 2gstratus.org for a lot of ideas on what you can do and what has been done another good forum would be the club3g eclipseforums.org since the cars share the same engine. Hope this helps.
Old Jul 2, 2005 | 03:04 AM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
Default RE: bolt on
i was a long time member of 2g, but it has turned into a flame site...
