Sensors Arrays and Failure Symptoms
Old Apr 14, 2011 | 05:43 PM
sunjay2513's Avatar
sunjay2513
Default Sensors Arrays and Failure Symptoms
I recently found this list while browsing, and I know a lot of us on here understand the sensors on vehicles, but some of the people on here are just learning, so I thought this may help them understand the functions of certain sensors and the failure symptoms.
MAP SENSOR: Stands for Manifold Absolute Pressure Sensor. It's nothing but an electronic vacuum gauge. As the manifold vacuum changes, the MAP sensor supplies a variable voltage to the computer.
FAILURE SYMPTOMS: Poor running, stalling, light (solid or flashing) on dash
NOTE: A MAP sensor can be inaccurate, sending an incorrect voltage to the computer. If this voltage is still within the range of voltage the computer expects, a light or trouble code for the MAP sensor may not be set. Fords are particularly susceptible to this. problem. Thus, if the MAP is old, it might be a good maintenance item.
TEMPERATURE SENSOR: Often a car will have several of these. All of them have a coolant/engine block temperature sensor. Some also have a manifold temp sensor and an intake air temperature sensor.
FAILURE SYMPTOMS: Rich or lean mixture, black smoke, light on dash
THROTTLE POSITION SENSOR: This lets the computer know how far you press the accelerator pedal down. It often has a wide open throttle and a closed throttle switch either as part of it or as separate components.
FAILURE SYMPTOMS: Hesitation on quick acceleration, sometimes bad idle. May not illuminate light or set codes.
MASS AIRFLOW SENSOR: The latest thing: this actually measures how much air enters the engine and adjusts the fuel/air mixture accordingly.
FAILURE SYMPTOMS: Poor running, stalling: all conditions. May not illuminate light or set codes.
OXYGEN SENSOR: This measures the exhaust oxygen content. The computer fine tunes the mixture using data from this sensor.
FAILURE SYMPTOMS: Poor fuel economy, driveability, light on dash.
(NOTE) HEGO SENSOR (Heated Oxygen Sensor): First seen on Fords, this is just an Oxygen sensor, except it's HEATED! Heated Exhaust Gas Oxygen sensor. It is electrically heated so it works immediately on engine startup: the other type must be heated by the exhaust before it starts to work. Computers using these place a lot more emphasis on the data from the oxygen sensor, and use this data sooner while the engine is still cold.
CRANKSHAFT/DISTRIBUTOR/CAMSHAFT POSITION SENSOR: Used on all engines with computerized timing advance, this tells the computer which cylinder should be firing. Some engines use a sensor on the front pulley of the engine (Harmonic balancer or vibration dampener), another sensor in the engine block on a special toothed wheel on the crankshaft inside the engine block, and a third sensor on the camshaft gear. Earlier systems have a pickup inside the distributor as the only input as to crank position.
FAILURE SYMPTOMS: No start, hesitation, misfire
BAROMETRIC PRESSURE SENSOR: This adjusts the mixture according to altitude.
FAILURE SYMPTOMS: Poor fuel economy, light on dash
In addition, the computer often monitors things like vehicle speed, brake pedal on or off, power steering pressure, A/C on or off, and transmission shifter position.
FAILURE SYMPTOMS: Poor fuel economy, light on dash, stalling while parking or at traffic lights
All vehicles do not have all of these sensors.
THE CRITICAL SENSORS:
For most cars the "essential" or "major" sensors are: MAP sensor, Mass Airflow Sensor (if so equipped), Engine Block Temperature Sensor, and the Crankshaft/Distributor Position Sensor. These sensors can make an engine barely run or not run at all. The other sensors make very fine adjustments to the fuel/air mix and timing and will not cause a gross poor running condition.
This is important, because often a "major" sensor will cause a "minor" sensor to read out of specs. If the car barely runs, or doesn't run at all, suspect one of these "major" sensors (and other non-computer stuff, like wiring, coil, or fuel supply) before trying to trace down a code generated by a "minor" sensor.
LIMP HOME MODE: When the computer decides enough sensor inputs are out of proper range, it will go to a "limp home mode". This mode has effects from almost unnoticeable to fairly radical, depending on what car you have. The mild case is a MIL light and bad gas mileage. Some cars (with computer shifted transmissions) will stay in second gear when in limp home mode!
In limp home mode, the computer uses assumed values to control fuel and spark rather than measured (and constantly adjusted) values. This results in poor fuel economy and bad driveability.
OBD 1 AND OBD 2 (OBD I AND OBD II)
In an effort to standardize computer control systems on vehicles, the government mandated manufacturers put a standardized data collection system on newer vehicles. This system is called OBD (On Board Data) one and two. The cars may have other proprietary data interfaces, but they MUST have the OBD interface if they are sold in the U.S.
The new interfaces have literally hundreds of trouble codes which can help a lot in diagnosing your vehicle. code scanners to read these codes have gotten much cheaper recently. Several parts stores will read these codes for free.
