electrical problem
Old Apr 21, 2011 | 04:06 PM
carcazy2011's Avatar
carcazy2011
Default electrical problem
I pulled some codes off car 2002 4dr 2.7 6
p1192 - intake air temp volts low
p01493 ambient battery temp sensor volt low,
p0405 EGR valve position sensor circuite signal low,
p0117 electonic coolant temp low volts,
p0122 throttle position sensor low volts
My question is what controls all these sensors with power for all of them to be on at the sametime? any help would be great thanks
Old Apr 23, 2011 | 02:24 PM
GALVANIZEDYANKEE's Avatar
GALVANIZEDYANKEE
5 Volts from the Power Control Module.
Old Apr 25, 2011 | 08:36 PM
ledsd's Avatar
ledsd
bad battery or alt
check output on alt and bat
check fuses and grounds
