2.4L DOHC - need help! won't stay on
Hello all,
I've recently purchased a 2002 Dodge Stratus with the 2.4L DOHC . I got it from a family member who hadn't driven it in 3 years. They tried to crank it to start it when they moved, but it wouldn't start. I towed the car home. After changing the oil, I got 2 5 gallon gas containers and filled the car with premium (93 octane) gas. I figured this would mix in with whatever bad gas was left in there (the needle was below E when I put the key in to check) and filter it out. I was able to start the car, and all seemed okay. I took it out for longer than 10 minutes for the first time today, and after a while my oil light starts to flicker on/off and stays on when I'm not moving. Once that starts happening, my RPM's will not rise above ~1500, and can only drive slow. After that happens, if I shut the engine off, the car won't turn back on unless I floor the pedal before cranking it and steadily give it gas.... otherwise it stalls out (I only did that twice, I'm very cautious with this car). I think there's something wrong with my fuel injectors maybe? I'm not a mechanic, just a handy guy.:icon_pimp: I'm sure it's not timing or anything like that... the car drives VERY smooth when running and only has 74k miles on it. ANY help is GREATLY appreciated. |
This car was in an accident. It was hit on the front end, but it only appeared to be cosmetic damage. I replaced the bumper cover and hood. That was all that was wrong. Is there an ASD for this car when it's in an accident? Maybe I need to reset it?
| All times are GMT -4. The time now is 12:58 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
