05 Stratus Air Filter replacement?
Old Jun 6, 2011 | 05:24 PM
billrod's Avatar
billrod
Default 05 Stratus Air Filter replacement?
Hi All
I tried to help a gal with an 05 Stratus, 2.7L V6.
I changed the oil and tried to change the air filter but was not able to figure out how to get the old filter out.
I saw there were 2 things like clips, one on each side that I could move to allow the old one to slide back a little but there was no room to remove it.
Cast into the duct work was to refer to the owners manual for filter replacement but the owners mannual did not state anything about how to get it out.
Anyone have any pic's or good explanation on this?
Thanks
Bill
Old Jun 7, 2011 | 05:41 AM
BillS's Avatar
BillS
if its the same as an 04 ,unhook clips you need to take the tubing(from filter back to throttle body) off to get filter out,carefully unhook hoses and any connections on tubing loosen hose clamp on throttle body remove tubing you have to move it around under accelarator cables then you can get to filter i sent you a private message with a picture
