an old 1986 dodge stratus
Old Jun 15, 2011 | 02:15 AM
classicfan1's Avatar
classicfan1
Originally Posted by sandimont
So, if I'm understanding u right, it all could lead back to the battery? I've not cleaned ALL the cables coming out. I guess that's what I should do before i find out what a ASD is. Thanks
oh, one more question, do u know where the starter and starter relay is on a 96 dodge? the motor is in sideways and backwards. Hell, the battery is under the drivers side front wheel finder. I even went at far as crawling under the car to look for it in the back and middle of the car.
The Dodge Stratus, along with many cars from the 80s-present are front wheel drive. The engine would be mounted differently due the position of the transmission.
The battery can be accessed by either fully turning or removing the drivers front wheel. There is a cover with plastic tabs you turn with your hand and it slides off-and voila! The battery!
(GM had the battery under the back seat in some cars, so this seems normal!)
