2001 stratus
Old Oct 20, 2011 | 04:38 PM
mlward29's Avatar
mlward29
Default 2001 stratus
I cant turn the key any advice on what it may be??
Old Oct 20, 2011 | 07:31 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Tap the head of the key with a little hammer.
Old Oct 20, 2011 | 11:33 PM
steak59's Avatar
steak59
that and spray some Lock lube into the key cylinder. If Lock lube is not avalible, just use WD-40
Old Oct 21, 2011 | 12:24 PM
ratsttam's Avatar
ratsttam
and if that doesn't work, you'll probably need to replace the cylinder.
Old Oct 21, 2011 | 06:45 PM
Evon Trizmo's Avatar
Evon Trizmo
How many miles are on the car? Usually when I see cars with 180K+ the actual key itself wears first and the part that goes in the igintion is all rounded off to like bumps on the key.
Usually if you pull the key out a hair and then turn it it works.
