2001 stratus fan/blower
Old Nov 6, 2011 | 03:58 PM
spiocola's Avatar
spiocola
Default 2001 stratus fan/blower
i have a 2001 stratus. it only blows out air if its on number 4. any suggestions? thanks!!!
Old Nov 6, 2011 | 04:53 PM
BillS's Avatar
BillS
if it only works on high speed most likely blower motor resistor is bad,should be located behind glove box remove trim underneath to access. resistor should be to left of blower motor held in place by 2 bolts. if you get at dealer resistor between 35-40 dollars
Old Nov 7, 2011 | 06:08 PM
microswitch's Avatar
microswitch
resistor is located behind the glove box. Push in the two prong on the side of the glove box and pull down. Removal of the box is very simple. There are two screws that hold the resistor inside the blower. Remove the screws. You may notice some rust ( maybe). Sometimes just by cleaning the rust the resistor will work normally again ( it has happened to me). Worse come to worse autozone will sell you one for about $50.00
