turn key, nothing happens
Old Dec 13, 2011 | 10:00 AM
jabeu's Avatar
jabeu
mine is a 2.7 liter. i am not sure about the 3.0. on the 2.7 it was under the car right behind the from exhaust manifold. i had to access it underneath. remove the air filter, front motor mount, catalytic convertor and the heat sheild surrounding it.
Old Jan 10, 2012 | 01:20 PM
alpinedog68's Avatar
alpinedog68
It should be near the front, passenger side. See if you can get it to turn over by jumping the posts as Master tech mentioned. I removed mine and had it tested. It "tested" ok at AutoZone, but it was a bit hesitant. I replaced it anyway as I was 99% sure that it was my problem (battery was good and charged).
To remove it, I only had to remove the sensor that screws into the exhaust manifold. FYI...that sucker was in there tight, be careful when wrenching it out. Also, cover the end with a clean rag while it is out. My car ran a little rough afterward and I figured I got a little oil on the sensor. Its all good now.
Old Apr 16, 2012 | 06:11 PM
skaowili's Avatar
skaowili
Thanks for the response Alpine, do you have a diagram that i can use as reference? I don't see it.
