The fuses seem to be fine so I'm not sure where to begin? The proper tank is filled with wiper fluid but not spraying through. Does anyone have a suggestion as to what could be wrong, or what specifically to check?
I opened the hood and held the sprayer lever on mine and found out that it was spraying...the hose was just not connected under the hood insulation. Worth a try...
Thanks guys, I ended up trying to replace the fuse even though it was good, and tried the switch a couple times. I think it may have actually been clogged, after a couple times flicking the switch a couple more times it eventually began spraying again.
My girlfriend had this issue after having a hood replaced, and it turned out that the hose was being pinched in the hood hinge...Might be worth a look at the hose.
