Heat Problem with 2002 Stratus R/T
Old Dec 10, 2011 | 11:07 AM
tomf2011's Avatar
tomf2011
Unhappy Heat Problem with 2002 Stratus R/T
I have a 2002 Stratus R/t with 34,000 miles on it and having a heating problem.
The heat is intermittent. The heat does blow HOT but then blows cold air (not a/c) then back to HOT/heat.
Has anyone had this problem? or could possibly give me an idea of what to check?
Thanks so much!
Old Dec 10, 2011 | 03:06 PM
BillS's Avatar
BillS
is it a sedan? if so you could try this ,think the m-1 fuse is first fuse in the inside fuse box or you could disconnect battery for 10 minutes.
NUMBER: 24-002-04 REV. A
GROUP: Heating & A/C
DATE: July 30, 2004
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 24-002-04, DATED MARCH 30, 2004, WHICH SHOULD BE REMOVED FROM YOUR FILES . ALL REVISIONS ARE HIGHLIGHTED WITH **ASTERISKS** AND INCLUDES ADDITIONAL MODEL YEAR.
SUBJECT:
A/C and Heater Performance
OVERVIEW:
This bulletin provides diagnostic information for A/C and heater performance complaints.
MODELS:
1998 - 2004 (LH) LHS/300M/Concorde/Intrepid2001 - **2005** (JR) Sebring Convertible/Sebring Sedan/Stratus Sedan
NOTE :Perform Customer Satisfaction Notification no. 857, reprogram Powertrain Control Module (PCM), for 2000 model year LH-vehicles built prior to August 30, 1999 (MDH 0830XX).
SYMPTOM/CONDITION:
Erratic operation of the A/C and heater systems including:
^Lack of cold air
^Lack of hot air
^Unrequested mode change - Automatic Temperature Control (ATC) only)
^No control of mode or temperature control
^Tapping noise from blend door
The above Symptoms may be accompanied by the following Diagnostic Trouble Codes (DTCs):
^Blend door feedback
^Blend door stall
^A/C control mode door input shorted to battery
^Mode door stall
^In car temp sensor failure ATC messages not received
DIAGNOSIS:
^Do not attempt to remove A/C control until after this entire Diagnosis and Repair Procedure has been performed.
^Verify customer reported symptom(s) if possible.
^Check for the presence of DTCs with the scan tool (DRBIII(R)) and record on the repair order. If a DRBIII(R) is not available reference the appropriate Service Manual - Heating and Air Conditioning "Self Diagnostics" procedure and record any present DTCs on the repair order. If Symptoms and/or DTCs other than those listed above are present, repair as necessary. If a Symptom(s) and/or DTC(s) listed above is present, perform the Repair Procedure.
REPAIR PROCEDURE:
1.With the vehicle at room temperature 10°- 27°C. (50°to 80°F.), remove the M-1 circuit fuse for ten minutes to erase DTCs.
2.Install the M-1 fuse and start the vehicle, this will initiate the HVAC system calibration. Allow approximately five minutes for the calibration to complete.
3.Operate the vehicle and HVAC system to verify that Symptoms and/or DTCs are gone. If tapping noise or Blend Stall/Feedback DTCs re-occur, additional diagnosis will be required
Old Dec 11, 2011 | 09:59 AM
tomf2011's Avatar
tomf2011
Thanks for the reply Bill!
The car is a 2-door coupe with a fuse box inside and one under the hood. Would the M-1 fuse be a regular mini fuse or a cartridge style?
Thanks Again
Old Dec 11, 2011 | 11:19 AM
BillS's Avatar
BillS
its a cartridge style(30 amp blower motor) inside door on my 04 sedan ,not sure on coupes. bulletin says it applies to sedans,might work on coupes also
