2004 Dodge Stratus
Old Dec 12, 2011 | 03:17 PM
october10's Avatar
october10
Default 2004 Dodge Stratus
does anyone know what might be the problem in a 2004 dodge stratus if the heat only blows hot works when I am accelerating? At an idle, the heat blows cold.......
Old Dec 13, 2011 | 01:00 AM
steak59's Avatar
steak59
probably either semi-clog heater core, or stuck open thermostat over cooling the engine at idle.
To check heater core, you'll just have to back flush it.
For checking thermostat, you'll have to rely on "feeling" the temperature on radiator hose, or reading data in scanner. Or simply replace it with a new one, since they r cheap.
Check coolant level too.
