96 stratus 2.4 water pump
Old Aug 6, 2005 | 05:39 PM
2001ramsport's Avatar
2001ramsport
Default 96 stratus 2.4 water pump
how hard is it to change a water pump on 2.4l engine? does any one know how much a dealer charges?[:@]
Old Aug 6, 2005 | 10:51 PM
thump186's Avatar
thump186
Default RE: 96 stratus 2.4 water pump
To reduce complexity, the base of the water pump housing is part of the block. The body of the pump is die cast aluminum, bolted to the front of the block. The pump is driven by the timing belt. The thermostat, radiator nipple, cooling system filler neck and overflow nipple are combined in a single unit.
from allpar.... i would think it is that difficult but more of a pain in the butt.
Old Aug 7, 2005 | 11:47 PM
2001ramsport
do you know if you have to jackup the enine ?
Old Aug 7, 2005 | 11:51 PM
thump186's Avatar
thump186
i'm not sure honestly you may be able to get at it through the wheel well
