Shifting Gears Problem
Old Mar 25, 2012 | 01:28 AM
yabuddy's Avatar
yabuddy
Default Shifting Gears Problem
I have an 2002 Stratus 3.0 v6 with 90k mi and my problem is when I try shifting from Drive to any other gear it won't go anywhere. It's fine when I'm shifting from Neutral to Reverse or Neutral to Park. Only happens when I'm going from Drive to another gear. At the moment I have to shut my car off then put it in Park lol.
Any information would be great, thanks!
Old Apr 14, 2012 | 01:09 PM
ndtguy's Avatar
ndtguy
First check your fluid level/color/feel. (By feel, I mean it doesn't feel gritty, if it does, time to change your fluid).
If all of the above are good to go, then check out this page. It may help you out. http://www.allpar.com/fix/trans.html
Old Apr 18, 2012 | 12:54 AM
yabuddy's Avatar
yabuddy
Already got it solved, thanks! It was as simple as adjusting the box that the air filter sits in.
