passenger door unlock
Old Aug 16, 2005 | 01:04 AM
kang25's Avatar
kang25
Default passenger door unlock
Anyone know if you can program the passenger door to open when the handle is pulled from the inside (locked obviously). Or can I take a locking mech. from the driverside door of another strat and put it in the passenger door. The problem is, when someone is riding with me, they have to hit unlock before they can get out of the car rather then just opening the door and it's a pain in the ***.
Old Aug 25, 2005 | 11:11 PM
hemipower1984's Avatar
hemipower1984
Default RE: passenger door unlock
nothing you can do they don't make a latch that works like that for this year of vechile except for divers side sorry
Old Aug 27, 2005 | 01:46 PM
bjshu96's Avatar
bjshu96
1. insert the key in the ignition. leave key in "off" postion
2. close both the driver and passenger door
3. press and hold the driver's central door lock swith until a chime sounds (10 seconds). the rolling lock feature will be swiched to On (if it off) or off (if it is on)
if the chime sounds once, the rolling lock feature is ON
if the chime sounds twice, the rolling lock feature is OFF
this works on 2005 might work on other years im not sure
hope this helps
Old Aug 28, 2005 | 01:08 AM
kang25's Avatar
kang25
I got it to beep, and nothing changed, then again and nothing changed (except one beep). Then tried it with the passenger door, and nothing changes but the number of beeps. This tells me I am toggling the rolling lock feature, but what is "rolling lock?"
