1998 srtatus crankshaft position senser
Old Nov 22, 2011 | 08:47 AM
Sloboat's Avatar
Sloboat
Default 1998 srtatus crankshaft position senser
Hello all. I am new to this forum and need some help. I have '98 stratus and I need to replace the crankshaft position senser The car has a 2.4 engine and an automatic trans. I was told it was down at the bottom drivers side of the motor near the crank pulley ( on the firewall side of engine)and one bolt holds the pulley cover on. Remove that and one bolt holds it in.That easy, sounds to good to be true! Thank you SLOBOAT
