Air Intake
Old Sep 8, 2005 | 10:37 PM
pvr02's Avatar
pvr02
Default RE: Air Intake
I did another test fit and the vacuum host is about 13 or 14 inches too short. After calling them, I found out that you are supposed to insert the silicon tube into the original one. I don't like the idea of doing that but will do it for a short term solution. I checked the auto stores around my area but was unable to find the tubes.
I found some kits that has 2ft of 10mm tube (which is the size I need). However, I need a length of around 25 or 26 inches. Doesn't anyone know anyplace online where I can buy 3 or get a custom length of Silicon Vacuum Hose?
Old Sep 8, 2005 | 11:03 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
if you go to any dealership with the stock hose, they have ROLLS of hose in the back..i worked at a stealership for a while...
Old Sep 12, 2005 | 01:20 AM
pvr02's Avatar
pvr02
Got it installed. You might want to check this out: Install Guide.
Old Sep 21, 2005 | 03:47 PM
pvr02's Avatar
pvr02
Probably a question I should have asked earlier but anyway. Is there any certain states laws or anything that I will need to watch out for? Specifically, I will be taking my car into dodge to get a problem taken care of as well as doing an oil change in a few weeks. Just wondering if I will get any grief from dodge or the oil service station?
