03 Stratus
I'm used to working on things without spark plugs so I need some help. 03 2.4 SOHC.....started out running rough with zero power. Timing belt is in really good shape and the arrows all line up. Discovered that 2 of the injectors weren't working. Went to the junk yard and got a full set out of an 01 Sebring. Replaced the 2 but for some reason there's one that refuses to function. I swapped the injector out with the other 3 with no results. The plug to the injector is pulsing alright....compression checks out good....the needle moves a little when I test the ohm's with the voltmeter.
Any suggestions?
Any suggestions?
