2000 dodge stratus se 2.4l a/t miss fires when fan on high .
Old Aug 8, 2012 | 12:01 PM
joshua91673's Avatar
joshua91673
Unhappy 2000 dodge stratus se 2.4l a/t miss fires when fan on high .
any ideas would be great
the problem is when i have the ac on and fan on high
it miss fires .or if i hold the window button up or down any thing draining the power , mostly the fan on high .
mechanic is clueless tested fuel pressure, crank sensor,plugs coil
replaced ecu/brain .it give no codes other than miss fire .engine light dosent come on .
p.s runs fine with out electric load .
not sure i explained my self good sorry .
josh
Old Aug 9, 2012 | 12:40 PM
joshua91673
Default bump
bump
bump
