help please
I am working on my 2000 dodge stratus for the timing belt.
The timing belt shreded because of the plastic shield rubbing on it.
I got a new one and am trying to replace it, but how do I know when the marks all line up that the number 1 piston is on the TDC comprssion stroke and not on the top of the exhaust stroke?
I would hate to find out after putting everything together that I have to rotate the crakshaft 180 degrees, and if the crank is off 180 degrees would the engine start? thanks for any help.
I know that the 2.5 is interference, so if it's off by 180, your smashing things together if you try to start it...
i would recommend searching online for "2000 stratus 2.4 timing" and if you see any from justanswer.com check out that link usually they have good diagrams, i can never get diagrams to load right here or try this linkwww.justanswer.com/dodge/1kios-doing-timing-belt-2000-dodge-stratus-2-4-liter.html
