02 Stratus SE wont start!
Old Nov 4, 2012 | 06:17 PM
Anthony Shabazz's Avatar
Anthony Shabazz
Default 02 Stratus SE wont start!
1 month ago water pump went bad
I thought hey if Im fixing that then why not fix the timing belt while its there
Last week timing belt pop (own error on putting the tension pully on)
Replaced Timing a few days ago Car was all good and going
About 20 minutes later im test driving my car turns off
I check the timing belt to see if it popped or anything, nope its all good
Push the car home take battery out and charge it put it back all good
Starter is good and alternator is good. Re-did the timing and tested about
3 times and it always lined up. So i come to you today to asked what can my
problem be?
Old Nov 5, 2012 | 03:54 AM
Anthony Shabazz
I did some test im thinking the Crankshaft Sensor . Sounds like a reasonable solution? right?
