2003 Stratus heater problems
Old Nov 13, 2012 | 11:46 PM
jenhill101's Avatar
jenhill101
Default 2003 Stratus heater problems
The fan only blows on level 4 and will not blow heat
any suggestions on what the problem could be?
Old Nov 14, 2012 | 12:07 AM
steak59's Avatar
steak59
Change the blower resistor, it will fix ur problem.
If you put in a new resistor, and it dies again within a year, then change the resistor WITH the blower motor.
Also, sometimes on the stratus, the new/redesigned resistor will be bigger, and not fit into the slot, you might have to trim the hole bigger with a razor knife.
you should find the blower and the resistor behind the glove box, just lay upside down on the passenger side floor with your flash light.
