MAP Sensor
Old Jan 16, 2013 | 04:22 PM
thekibs's Avatar
thekibs
Default MAP Sensor
I have a 2001 Dodge Stratus 3.0L and received a P1400 code recently. I looked it up and found out that it means there is a malfunction with the manifold differential pressure sensor (if this is true, I'm not too sure) or MAP sensor. Would removing the MAP sensor and cleaning it remove the code?
